support-us@roborock.com
1-855-960-4321
Helpline hours: 24/7, US only
②5GHz:
Similarities:
1. All models include essential functions such as Auto-Empty, Mop Washing, Water Refilling, Auto-Drying, and Dock Self-Cleaning.
2. They all come with several carpet cleaning settings, High-speed Sonic Mopping, and DuoRoller Riser® Brush.
3. They all have an automatic brush and mop lifting function.
Differences:
1. Only S8 MaxV Ultra and S8 Max Ultra are equipped with the FlexiArm Design™ Side Brush, Hot Water Mop Washing, Edgewise Mop Cloth, and Auto Detergent Dispenser.
2. Only S8 MaxV Ultra comes with an Intelligent Voice Assistant and remote viewing capability.
3. S8 MaxV Ultra and S8 Max Ultra feature an 100ml built-in water tank, a 4L clean water tank, and 270ml dustbin. In comparison, S8 Pro Ultra boasts a 200ml built-in water tank, a 3.5L clean water tank, and 350ml dustbin.
4. S8 MaxV Ultra and S8 Max Ultra include Roborock Smart Plan, which automatically customizes the optimal cleaning plan based on the home environment and past cleaning habits.
5. S8 MaxV Ultra and S8 Max Ultra offer additional features such as "Add Area" for targeted re-cleaning and "Skip Area" to bypass specific areas for efficiency, neither of which are available on S8 Pro Ultra.
6. There is a heating module inside dock of S8 MaxV Ultra and S8 Max Ultra to heat water in the clean sink to 60℃. With 60℃ hot water, most greasy dirt can be dissolved, while S8 Pro Ultra only uses room temperature water to wash the mops.
We suggest you place the dock on a hard and flat floor (wood/tile/concrete etc.), flat against a wall. Keep at least 0.7 m (2.3 ft) in front and 0.5 m (1.6 ft) above.
The following applies to S7Max Ultra, S8, S8+, S8 Pro Ultra and Q Revo:
The robot vacuum cleans in a zig-zag pattern only to enable faster and more efficient cleaning that saves time. Room boundaries will be skipped and certain spots may be missed. This function is ideal for daily cleaning.
Yes, the robot will clean the floor along its direction to minimize scraping against floor seams in full cleaning or room cleaning. Please set up floor direction and enable “clean along floor direction” in the app for this feature to work.
S8 and S8+ still adopts VibraRise system like S7. However, the vibration modules of S8Pro Ultra have been improved two-fold with two vibrating areas, providing higher efficiency during cleaning.
Drying duration can be modified under app “Dock Settings” .
Drying starts automatically after mop washing or after cleaning are completed. To manually start or stopping drying, tap Drying button in the app.
Auto-drying can be disabled through the app.
1. Only the following models support QR code.
Roborock Q7 Max Series
Roborock Q7 Series
Roborock Q5 Series
Roborock S8 Series
Roborock Q Revo
Roborock Q5 Pro Series
Roborock Q8 Max Series
Other models don't support QR code.
2. I cannot find the QR code.
Some products do not have QR code. To add one of these devices, go to the Roborock app homepage and tap "Search for Device". Please tap on "No QR code found" and proceed with the next step. See picture below:
3. If I'm using the models that supports QR code, where's the QR code?
The QR code is located below the top cover or dustbin or on the top of the machine.
The following applies to Auto-Empty Dock Pure, RockDock Plus, RockDock Ultra and Multifunctional Dock.
We suggest you replace the disposable dust bag every 7 weeks. It depends on actual use.
The following applies to Empty wash fill dock, RockDock Ultra and Multifunctional Dock.
There are 3 cleaning modes available, Light, Balanced, and Deep.
Light mode is suitable for clean environment, with reduced cleaning time and water consumption.
Balanced is suitable for medium-sized homes, with balanced cleaning speed and performance.
Deep is suitable for occasional deep cleaning, with higher water consumption and longer cleaning time.
The following applies to S7maxV Ultra, S7Max Ultra, S8 Pro Ultra and Q Revo.
Wash frequency is 20 minutes by default, you can change it on wash settings page of the app. If needed, you can also start mop washing manually by pressing and holding Dock button when robot on the dock.
To prevent corrosion or damage, only use Roborock branded floor cleaner in the water tank.
The link below is for reference:
They are Dirty Water Tank, Clean Water Tank, and Dustbin from left to right.
The following applies to Q Revo, S8 Pro Ultra, S8+, S8, S7Max Ultra, S7MaxV, S7, S6MaxV, S6Pure, S5Max and S4Max.
You can set the device to do a zone/room cleaning for more than once. In this way, the device will follow a cross-hatch pattern.
The following applies to Roborock S7, S7MaxV, S7Max Ultra, S6MaxV, S8, S8+ and S8 Pro Ultra only.
There are two ways to turn on child lock.
Once the child lock is enabled, the device will not respond if any button is pressed until you disable the lock.
The following applies to S7, S7MaxV, S7Max Ultra, S8, S8+, S8 Pro Ultra and Q Revo only.
The device is equipped with ultrasonic carpet recognition. It can recognize carpet with extraordinary accuracy. You can choose different carpet modes according to your needs. For example, you can set the robot to lift its mop automatically when it detects carpet. That mode is recommended for short-pile carpet.
Notice:
Yes. Onboard cliff sensors will detect any drops and prevent the robot from falling.
Related FAQ:What is the maximum height of a threshold that Roborock can pass over? |
Notes:
Related FAQ:
Notes:
Note:
Related FAQ:
Related FAQ:
Notes:
Note:
Related FAQ:
Related FAQ: |
For a detailed guide to the Roborock app and its main features, please see our App User Guide.
https://gl-files.roborock.com/app-manuals/54fb3c0a2c94a536a3ecc501bb7430977b4e250d4b376d88.pdf
The guide provides step-by-step instructions for using the app. Please note that some features are model-specific, so certain options may not appear on your device. The app interface may also vary slightly by model or app version. Screenshots are for reference, while the basic steps and functions remain generally applicable.
If you need further assistance, just let us know.
1-855-960-4321
