support-us@roborock.com
1-855-960-4321
Helpline hours: 24/7, US only
②5GHz:
The following applies to S7Max Ultra, S8, S8+, S8 Pro Ultra and Q Revo:
The robot vacuum cleans in a zig-zag pattern only to enable faster and more efficient cleaning that saves time. Room boundaries will be skipped and certain spots may be missed. This function is ideal for daily cleaning.
Yes, the robot will clean the floor along its direction to minimize scraping against floor seams in full cleaning or room cleaning. Please set up floor direction and enable “clean along floor direction” in the app for this feature to work.
1. Only the following models support QR code.
Roborock Q7 Max Series
Roborock Q7 Series
Roborock Q5 Series
Roborock S8 Series
Roborock Q Revo
Roborock Q5 Pro Series
Roborock Q8 Max Series
Other models don't support QR code.
2. I cannot find the QR code.
Some products do not have QR code. To add one of these devices, go to the Roborock app homepage and tap "Search for Device". Please tap on "No QR code found" and proceed with the next step. See picture below:
3. If I'm using the models that supports QR code, where's the QR code?
The QR code is located below the top cover or dustbin or on the top of the machine.
The following applies to S7, S7MaxV, S8 and S8 Pro Ultra.
There are 2 ways to achieve that:
1) Please remove the water tank and then start cleaning
2)Choose Vacuum instard of Vac&Mop or Mop.
Note: The UI may change as firmware updates without prior notice.
The following applies to Q Revo, S8 Pro Ultra, S8+, S8, S7Max Ultra, S7MaxV, S7, S6MaxV, S6Pure, S5Max and S4Max.
You can set the device to do a zone/room cleaning for more than once. In this way, the device will follow a cross-hatch pattern.
The following applies to Roborock S7, S7MaxV, S7Max Ultra, S6MaxV, S8, S8+ and S8 Pro Ultra only.
There are two ways to turn on child lock.
Once the child lock is enabled, the device will not respond if any button is pressed until you disable the lock.
The following applies to S7, S7MaxV, S7Max Ultra, S8, S8+, S8 Pro Ultra and Q Revo only.
The device is equipped with ultrasonic carpet recognition. It can recognize carpet with extraordinary accuracy. You can choose different carpet modes according to your needs. For example, you can set the robot to lift its mop automatically when it detects carpet. That mode is recommended for short-pile carpet.
Notice:
Yes. Onboard cliff sensors will detect any drops and prevent the robot from falling.
Related FAQ:What is the maximum height of a threshold that Roborock can pass over? |
Notes:
Related FAQ:
Notes:
Note:
Related FAQ:
Related FAQ:
Notes:
Note:
Related FAQ:
We are sorry to tell you that our products do not alert when a dustbin is full, only when it has not been emptied for an extended period. We recommend emptying the dustbin regularly.
Related FAQs:Will I receive an alert when the water tank is empty? What does "MAX" on the transparent dust bin mean?
Related Tutorials Video:Roborock S6 Emptying and Cleaning the Dustbin Roborock S5 Emptying and Cleaning the Dustbin |
Related FAQ: |
1-855-960-4321
