support-us@roborock.com
1-855-960-4321
Helpline hours: 24/7, US only
①Auto-emptying is disabled. Check in-app settings.
②Dock dust container cover is not installed. Check and install. If the dust bag is full, please replace it.
③Auto-emptying will not be triggered if the robot returns to the dock without cleaning.
④The robot will not auto-empty after returning to the dock in the Do Not Disturb (DND) mode. Adjust cleaning or DND duration, or start emptying manually.
Please follow steps below to check the robot.
①Check that local voltage meets the requirements listed on the dock.
②Check clean water tank placement or refill as required.
③Check dirty water tank placement or empty as required.
④Check that the cleaning tank or cleaning tank filter has been correctly installed.
1). Ensure you already chose washing water temperature as Hot water.
2). Hot water will be used in the early stage of the main mop washing process to cooperate with the cleaning liquid. During this period, the maximum temperature of the hot water can reach 60°C. (affected by the ambient temperature and the water temperature of the clean water tank, the hot water outlet temperature will change).
It is recommended that you press the pause button half a minute after washing starts and then take the robot off the dock off the dock to feel the temperature of the mop.
The following applies to Empty Wash Fill Dock, S8 Pro Ultra and S7Max Ultra:
If the issue persists, please contact Customer Support for further assistance.
The cliff sensors used on robot cleaner make the device may not be able to clean shag carpets because the long hairs may trigger the cliff sensors in the same way as a drop. At present, it is not possible to disable cliff sensors as they are essential in most homes.
Why does robot cleanner refuse to clean the dark carpet?
Try each of the following steps until the noise stops. After each step, run the robot briefly to see if the noise continues. If not re-install the part and move on to the next step until the noise stops. If the noise stops, clean the part thoroughly then reinstall it and try again.
- Remove the main brush and brush cover
- Unscrew and remove the side brush
- Uninstall the front wheel (keeping the front of the robot supported)
If the noise ceases when the front wheel is removed, after cleaning, pour no more than two drops of olive oil down the wheel shaft and rotate it to spread the oil before reinstallation.
If none of the above have stopped the noise, turn the driving wheels manually. If they are, the source of the noise, contact your Roborock dealer for further support.
The robot might experience issues returning to its dock if it was started in a different location, if it is hitting an obstacle, or if it was moved manually. If this is occurring, try one of the below solutions:
Move the dock to a new location and see if the robot can locate it. The dock should be placed against a wall, have at least 0.5m of clearance either side and 1.5m in front. Then, clean the front signal transmission area of the dock and the robot’s front sensor, both of which are used for the robot to locate the dock.
First, make sure there are no obstacles preventing access to the missed areas.
Second, most missed areas and abnormal cleaning paths are caused by dirt on the wall sensor on the right of the robot. Use a damp cloth to wipe the wall sensor and run another cleanup to see if this has resolved your issue.
Roborock Internal Error: Restore the robot cleaner to factory setting. If you continue to experience this error, contact Roborock Customer Support.
1-855-960-4321
