support-us@roborock.com
1-855-960-4321
Helpline hours: 24/7, US only
The robot consumes little power. For example:
With the robotic arm disabled and the Mop Wash Frequency set to 15 minutes, the robot can keep vacuuming/mopping for about 2 hours and 15 minutes or more, cleaning a room with a floor area of about 180 square meters at a time;
With the robotic arm enabled and the Mop Wash Frequency set to 15 minutes, assuming the robotic arm tidies up 10 items during cleaning, the robot can clean a room with a floor area of about 150 square meters at a time;
Generally, if you remotely control the robotic arm to pick up items without cleaning, each operation consumes about 1% of the power.
The above data is only for reference. The actual results vary with the situation of the items on the floor and the Mop Wash Frequency or other settings.
With active cutting technology, the robot can cut hair with its main brush when cleaning and easily vacuum the hair with powerful suction. However, if there is too much hair during daily cleaning, the main brush may not be able to vacuum the hair in time, causing entanglement. So we recommend cleaning it regularly.
Saros Z70 is designed with multiple safety protection devices/mechanisms to prevent the moving robotic arm from injuring users, children and pets. These mechanisms include:
Saros Z70's retractable 5-axis robotic arm retracts to its compartment when idle and extends during cleaning. Its features include:
In addition, the robotic arm will support more features through OTA updates.
Like Saros 10R, Saros Z70 also boasts the AdaptiLift™ chassis, FlexiArm Riser side brush and liftable FlexiArm mop, and supports features such as self-cleaning. With a 7.98 cm ultra-thin body, it delivers an excellent floor cleaning performance based on the latest technology.
1-855-960-4321
