support-us@roborock.com
1-855-960-4321
Helpline hours: 24/7, US only
You can control Roborock robots through Alexa by the following 2 kinds of Command:
Command A: Say "Alexa, ask robo rock to clean the bedroom" to Alexa directly.
Command B: Say "Alexa, open robo rock" first, and then say the other part of the command like "clean the bedroom" (no need to add "ask robo rock to" in the dialogue) after Alexa has given a response.
Command B would work in most circumstances while Command A doesn't work.
Clean the filter, dry it thoroughly and place it back in the robot then try again.
If you continue to experience this error, contact Roborock Customer Support.
The cliff sensors used on robot cleaner make the device may not be able to clean shag carpets because the long hairs may trigger the cliff sensors in the same way as a drop. At present, it is not possible to disable cliff sensors as they are essential in most homes.
Why does robot cleanner refuse to clean the dark carpet?
The cliff sensors used on Roborock robots may mean that the robot may not be able to clean dark carpet because dark carpets trigger the cliff sensors in the same way as a drop. At present, it is not possible to disable cliff sensors as they are essential in most homes. Hope you can understand and forgive this drawback.
Why does robot cleanner refuse to clean the shag carpet?
Try each of the following steps until the noise stops. After each step, run the robot briefly to see if the noise continues. If not re-install the part and move on to the next step until the noise stops. If the noise stops, clean the part thoroughly then reinstall it and try again.
- Remove the main brush and brush cover
- Unscrew and remove the side brush
- Uninstall the front wheel (keeping the front of the robot supported)
If the noise ceases when the front wheel is removed, after cleaning, pour no more than two drops of olive oil down the wheel shaft and rotate it to spread the oil before reinstallation.
If none of the above have stopped the noise, turn the driving wheels manually. If they are, the source of the noise, contact your Roborock dealer for further support.
The robot might experience issues returning to its dock if it was started in a different location, if it is hitting an obstacle, or if it was moved manually. If this is occurring, try one of the below solutions:
Move the dock to a new location and see if the robot can locate it. The dock should be placed against a wall, have at least 0.5m of clearance either side and 1.5m in front. Then, clean the front signal transmission area of the dock and the robot’s front sensor, both of which are used for the robot to locate the dock.
Zone cleaning may fail if the zone is set in an area that was previously behind a closed door.
Start a normal cleanup near the open door, then start a zone cleanup once the robot has realized the door is open.
First, make sure there are no obstacles preventing access to the missed areas.
Second, most missed areas and abnormal cleaning paths are caused by dirt on the wall sensor on the right of the robot. Use a damp cloth to wipe the wall sensor and run another cleanup to see if this has resolved your issue.
The map displayed in-app should only be horizontal or vertical. If it appears at an angle, this may be due to the placement of the dock. Move the dock to a new location, with at least 0.5m of clearance on either side and 1.5m in front. You can also try switching off Map Saving then switching it back to create a new map with your next cleanup.
How to create multiple maps for multi-level house?
Can I make the robot cleaner clean specific rooms?
Check the blocked strainer, and repalce the filter to see if the problem is solved.
Roborock Internal Error: Restore the robot cleaner to factory setting. If you continue to experience this error, contact Roborock Customer Support.
Roborock Error 5: Make sure that there is nothing tangling up the main brush, including inside the two brush installation slots and at either end of the brush, then run the robot with Carpet mode enabled and see if the problem has been resolved. If you continue to experience this error, contact Roborock Customer Support.
Roborock Error 4: Wipe the cliff sensors and make sure the robot cleaner is not on the dark or shag carpet. If you continue to experience this error, contact Roborock Customer Support.
1-855-960-4321
