support-us@roborock.com
1-855-960-4321
Helpline hours: 24/7, US only
1. Only the following models support QR code.
Roborock Q7 Max Series
Roborock Q7 Series
Roborock Q5 Series
Roborock S8 Series
Roborock Q Revo
Roborock Q5 Pro Series
Roborock Q8 Max Series
Other models don't support QR code.
2. I cannot find the QR code.
Some products do not have QR code. To add one of these devices, go to the Roborock app homepage and tap "Search for Device". Please tap on "No QR code found" and proceed with the next step. See picture below:
3. If I'm using the models that supports QR code, where's the QR code?
The QR code is located below the top cover or dustbin or on the top of the machine.
QRcode: Scan the QR code below to download and install the app:
App Store:
https://apps.apple.com/us/app/roborock/id1462875428
Google Play:
https://play.google.com/store/apps/details?id=com.roborock.smart&hl=en&gl=US
The following applied to all roborock products.
We do not recommend adding non-roborock cleaner into the water tank as bubbles created by the cleaner may block the filter. If you use roborock cleaner, please dilute it (dilution ratio 1:300) before using.
You can set the device to clean a specific area, room, or the whole house at one touch in the Routines. You can also set schedules in the Routines so that the device can be scheduled to clean a specific area, room, or the whole house.
The following applies to Empty wash fill dock, RockDock Ultra and Multifunctional Dock.
There are 3 cleaning modes available, Light, Balanced, and Deep.
Light mode is suitable for clean environment, with reduced cleaning time and water consumption.
Balanced is suitable for medium-sized homes, with balanced cleaning speed and performance.
Deep is suitable for occasional deep cleaning, with higher water consumption and longer cleaning time.
The following applies to S7maxV Ultra, S7Max Ultra, S8 Pro Ultra and Q Revo.
Wash frequency is 20 minutes by default, you can change it on wash settings page of the app. If needed, you can also start mop washing manually by pressing and holding Dock button when robot on the dock.
It depends on actual use. For reference, a full water tank is enough for 3-4 days usage to vacuum and mop a 100-square-meter house once a day, with default washing settings, i.e. 20 minutes mop wash frequency and balanced washing mode.
All docks are subject to water-based tests before leaving the factory. It is normal that a small amount of water remains in the waterway of the dock.
To prevent corrosion or damage, only use Roborock branded floor cleaner in the water tank.
The link below is for reference:
They are Dirty Water Tank, Clean Water Tank, and Dustbin from left to right.
We suggest you place the dock on a hard and flat floor (wood/tile/concrete etc.), flat against a wall. Keep at least 0.5 m (1.6 ft) of clearance on either side, 1.5 m (4.9 ft) in front, and 1 m (3.3 ft) above.
Its side brush, main brush, dustbin, filter, main brush, and brush cover are compatible with that of S7. Its water tank is not compatible with any of the previous models.
The sound comes from the floating ball inside the water tank. Please don’t worry about that.
These are the molding lines of the water tan and are not cracks. They are normal and will not affect the performance and sealing capacity of the water tank.
The following applies to S7, S7MaxV, S8 and S8 Pro Ultra.
There are 2 ways to achieve that:
1) Please remove the water tank and then start cleaning
2)Choose Vacuum instard of Vac&Mop or Mop.
Note: The UI may change as firmware updates without prior notice.
S7MaxV is equipped with 3D structured light and RGB camera for obstacle recognition and avoidance. Its Vibrarise mopping system makes it better able to deal with carpet. Besides, S7MaxV is compatible with an Auto-Empty Dock and Empty Wash Fill dock.
The following applies to Roborock S7, S7MaxV, S7Max Ultra, S6MaxV, S8, S8+ and S8 Pro Ultra only.
There are two ways to turn on child lock.
Once the child lock is enabled, the device will not respond if any button is pressed until you disable the lock.
Mihome app user
Mihome app user:
Roborock app user:
The following applies to S7, S7MaxV, S7Max Ultra, S8, S8+, S8 Pro Ultra and Q Revo only.
The device is equipped with ultrasonic carpet recognition. It can recognize carpet with extraordinary accuracy. You can choose different carpet modes according to your needs. For example, you can set the robot to lift its mop automatically when it detects carpet. That mode is recommended for short-pile carpet.
MI ID A: Owner of device
MI ID B: Who wants to have device from owner.
But please notice the shared function is designed to just allow some basic features to be used by account shared. If MI ID B needs the whole features of device, we suggest he uses the owner's Mi account as one Mi account could be signed in on multiple phones.
Can multiple people control the robot by using different Mi accounts?
Notice:
Yes. Onboard cliff sensors will detect any drops and prevent the robot from falling.
Related FAQ:What is the maximum height of a threshold that Roborock can pass over? |
Notes:
Related FAQ:
Notes:
Note:
Related FAQ:
Related FAQ:
Notes:
Note:
Related FAQ:
We are sorry to tell you that our products do not alert when a dustbin is full, only when it has not been emptied for an extended period. We recommend emptying the dustbin regularly.
Related FAQs:Will I receive an alert when the water tank is empty? What does "MAX" on the transparent dust bin mean?
Related Tutorials Video:Roborock S6 Emptying and Cleaning the Dustbin Roborock S5 Emptying and Cleaning the Dustbin |
Related FAQ: |
1-855-960-4321
