support-us@roborock.com
1-855-960-4321
Helpline hours: 24/7, US only
The following applies to S7Max Ultra, S8, S8+, S8 Pro Ultra and Q Revo:
The robot vacuum cleans in a zig-zag pattern only to enable faster and more efficient cleaning that saves time. Room boundaries will be skipped and certain spots may be missed. This function is ideal for daily cleaning.
Yes, the robot will clean the floor along its direction to minimize scraping against floor seams in full cleaning or room cleaning. Please set up floor direction and enable “clean along floor direction” in the app for this feature to work.
Drying duration can be modified under app “Dock Settings” .
Drying starts automatically after mop washing or after cleaning are completed. To manually start or stopping drying, tap Drying button in the app.
Auto-drying can be disabled through the app.
The following applies to Auto-Empty Dock Pure, RockDock Plus, RockDock Ultra and Multifunctional Dock.
We suggest you replace the disposable dust bag every 7 weeks. It depends on actual use.
The following applies to Empty wash fill dock, RockDock Ultra and Multifunctional Dock.
There are 3 cleaning modes available, Light, Balanced, and Deep.
Light mode is suitable for clean environment, with reduced cleaning time and water consumption.
Balanced is suitable for medium-sized homes, with balanced cleaning speed and performance.
Deep is suitable for occasional deep cleaning, with higher water consumption and longer cleaning time.
The following applies to S7maxV Ultra, S7Max Ultra, S8 Pro Ultra and Q Revo.
Wash frequency is 20 minutes by default, you can change it on wash settings page of the app. If needed, you can also start mop washing manually by pressing and holding Dock button when robot on the dock.
To prevent corrosion or damage, only use Roborock branded floor cleaner in the water tank.
The link below is for reference:
They are Dirty Water Tank, Clean Water Tank, and Dustbin from left to right.
The following applies to Q Revo, S8 Pro Ultra, S8+, S8, S7Max Ultra, S7MaxV, S7, S6MaxV, S6Pure, S5Max and S4Max.
You can set the device to do a zone/room cleaning for more than once. In this way, the device will follow a cross-hatch pattern.
The following applies to Roborock S7, S7MaxV, S7Max Ultra, S6MaxV, S8, S8+ and S8 Pro Ultra only.
There are two ways to turn on child lock.
Once the child lock is enabled, the device will not respond if any button is pressed until you disable the lock.
The following applies to S7, S7MaxV, S7Max Ultra, S8, S8+, S8 Pro Ultra and Q Revo only.
The device is equipped with ultrasonic carpet recognition. It can recognize carpet with extraordinary accuracy. You can choose different carpet modes according to your needs. For example, you can set the robot to lift its mop automatically when it detects carpet. That mode is recommended for short-pile carpet.
Notice:
Yes. Onboard cliff sensors will detect any drops and prevent the robot from falling.
Related FAQ:What is the maximum height of a threshold that Roborock can pass over? |
Notes:
Related FAQ:
Notes:
Note:
Related FAQ:
Related FAQ:
Notes:
Note:
Related FAQ:
Related FAQ: |
1-855-960-4321
