support-us@roborock.com
1-855-960-4321
Helpline hours: 24/7, US only
1. Only the following models support QR code.
Roborock Q7 Max Series
Roborock Q7 Series
Roborock Q5 Series
Roborock S8 Series
Roborock Q Revo
Roborock Q5 Pro Series
Roborock Q8 Max Series
Other models don't support QR code.
2. I cannot find the QR code.
Some products do not have QR code. To add one of these devices, go to the Roborock app homepage and tap "Search for Device". Please tap on "No QR code found" and proceed with the next step. See picture below:
3. If I'm using the models that supports QR code, where's the QR code?
The QR code is located below the top cover or dustbin or on the top of the machine.
QRcode: Scan the QR code below to download and install the app:
App Store:
https://apps.apple.com/us/app/roborock/id1462875428
Google Play:
https://play.google.com/store/apps/details?id=com.roborock.smart&hl=en&gl=US
The following applied to all roborock products.
We do not recommend adding non-roborock cleaner into the water tank as bubbles created by the cleaner may block the filter. If you use roborock cleaner, please dilute it (dilution ratio 1:300) before using.
The following applies to Q Revo, S8 Pro Ultra, S8+, S8, S7Max Ultra, S7MaxV, S7, S6MaxV, S6Pure, S5Max and S4Max.
You can set the device to do a zone/room cleaning for more than once. In this way, the device will follow a cross-hatch pattern.
Mihome app user
Mihome app user:
Roborock app user:
You can check below table for more information.
How long does it take to charge the Roborock H6?
Why is the battery not full even after charging for a long time?
The climbing ability of all the products, except S4 is 2cm (0.79inch), including S6 MaxV, S6 Pure, S6, S6 Max, S5, E4, E2/E3, C1, while the S4 is 1.5 cm (0.59inch).
When robot is creating the first map.
1. Map saved mode is enabled.You can go to "Vacuum settings" page or "Edit map" page.
2. Robot starts from dock.
3. Robot goes everywhere on map it detects to clean, not just somewhere. Pls make sure the doors are open for the rooms you want to be displayed on map.
4. Robot returns to dock(whose position is not moved) by itself and successfully.
Roboorck Plus is a skill that will allow users to bind their Roboorck ID to the Amazon Alexa. After account linked, users will be able to control the Roborock devices via Alexa.
Note: Make sure your robot is added and online on Roborock app (not Mi Home) first.
How do I connect robot vacuum to alexa via skill Roborock Home or Mi Home?
You could set schedule cleaning on app. See picture below:
How do I set schedule cleaning for Roborock E series?
Why does S6 MaxV not support scheduled room cleaning anymore?
Will Roborock robot support scheduled room cleaning with multi-floor maps feature enabled?
Notice:
Standard dock can operate between 100 V-240 V AC (Volts Alternating Current).
Auto-Empty Dock (or any dock with emptying function) works as follows:
US version: 100V-120V
EU version: 220V-240V
AU version: 220V-240V
JP version: 100V-127V
KR version: 220V-240V
TW version: 100V-127V
RU version: 220V-240V
UK version: 220V-240V
Check your regional voltage before use.
Notes:
Related FAQ:
Notes:
Note:
Related FAQ:
Related FAQ:
Notes:
Note:
Related FAQ:
| We are sorry to tell you that your vacuum cleaner is Non-Chinese version and can't work together with your other Mi devices with Chinese version under China Mainland server. This is because we have to comply with local country laws that device's data could not be saved in a server in China. Sorry for that and hope you can understand and forgive it. |
Yes. Mi Home app supports the feature. You could use your phone to control the robot cleaner. It applies to all products. Roborock app has this feature, which applies to S4, S5 Max, S6, S6 Pure, S6 MaxV and S4 Max, and S7. |
No. We recommend adding water into it regularly.
Related FAQs:Will I receive an alert when the dustbin is full? Can I add cleaner into the water tank when moppings? What should I do when there is little water leaking from tank and mopping cloth is almost dry? |
We are sorry to tell you that our products do not alert when a dustbin is full, only when it has not been emptied for an extended period. We recommend emptying the dustbin regularly.
Related FAQs:Will I receive an alert when the water tank is empty? What does "MAX" on the transparent dust bin mean?
Related Tutorials Video:Roborock S6 Emptying and Cleaning the Dustbin Roborock S5 Emptying and Cleaning the Dustbin |
Related FAQ: |
1-855-960-4321
