support-us@roborock.com
1-855-960-4321
Helpline hours: 24/7, US only
②5GHz:
1. Only the following models support QR code.
Roborock Q7 Max Series
Roborock Q7 Series
Roborock Q5 Series
Roborock S8 Series
Roborock Q Revo
Roborock Q5 Pro Series
Roborock Q8 Max Series
Other models don't support QR code.
2. I cannot find the QR code.
Some products do not have QR code. To add one of these devices, go to the Roborock app homepage and tap "Search for Device". Please tap on "No QR code found" and proceed with the next step. See picture below:
3. If I'm using the models that supports QR code, where's the QR code?
The QR code is located below the top cover or dustbin or on the top of the machine.
QRcode: Scan the QR code below to download and install the app:
App Store:
https://apps.apple.com/us/app/roborock/id1462875428
Google Play:
https://play.google.com/store/apps/details?id=com.roborock.smart&hl=en&gl=US
The following applied to all roborock products.
We do not recommend adding non-roborock cleaner into the water tank as bubbles created by the cleaner may block the filter. If you use roborock cleaner, please dilute it (dilution ratio 1:300) before using.
Mihome app user
Mihome app user:
Roborock app user:
You can check below table for more information.
How long does it take to charge the Roborock H6?
Why is the battery not full even after charging for a long time?
The climbing ability of all the products, except S4 is 2cm (0.79inch), including S6 MaxV, S6 Pure, S6, S6 Max, S5, E4, E2/E3, C1, while the S4 is 1.5 cm (0.59inch).
When robot is creating the first map.
1. Map saved mode is enabled.You can go to "Vacuum settings" page or "Edit map" page.
2. Robot starts from dock.
3. Robot goes everywhere on map it detects to clean, not just somewhere. Pls make sure the doors are open for the rooms you want to be displayed on map.
4. Robot returns to dock(whose position is not moved) by itself and successfully.
MI ID A: Owner of device
MI ID B: Who wants to have device from owner.
But please notice the shared function is designed to just allow some basic features to be used by account shared. If MI ID B needs the whole features of device, we suggest he uses the owner's Mi account as one Mi account could be signed in on multiple phones.
Can multiple people control the robot by using different Mi accounts?
Roboorck Plus is a skill that will allow users to bind their Roboorck ID to the Amazon Alexa. After account linked, users will be able to control the Roborock devices via Alexa.
Note: Make sure your robot is added and online on Roborock app (not Mi Home) first.
How do I connect robot vacuum to alexa via skill Roborock Home or Mi Home?
Roborock Home is a skill that will allow users to bind their Mi ID to the Alexa. After account linked, users will be able to control the Roborock devices via Alexa.
Note: Make sure your robot is added and online on Mi Home app first.
Note: At present, Alexa smart speaker could only start and stop robot by skill Roborock Home or Mi Home.
You could set schedule cleaning on app. See picture below:
How do I set schedule cleaning for Roborock E series?
Why does S6 MaxV not support scheduled room cleaning anymore?
Will Roborock robot support scheduled room cleaning with multi-floor maps feature enabled?
Notice:
Standard dock can operate between 100 V-240 V AC (Volts Alternating Current).
Auto-Empty Dock (or any dock with emptying function) works as follows:
US version: 100V-120V
EU version: 220V-240V
AU version: 220V-240V
JP version: 100V-127V
KR version: 220V-240V
TW version: 100V-127V
RU version: 220V-240V
UK version: 220V-240V
Check your regional voltage before use.
Yes. Onboard cliff sensors will detect any drops and prevent the robot from falling.
Related FAQ:What is the maximum height of a threshold that Roborock can pass over? |
Notes:
Related FAQ:
Notes:
Note:
Related FAQ:
Related FAQ:
Notes:
Note:
Related FAQ:
| We are sorry to tell you that your device is Chinese mainland version which could only be accessed on app in China mainland. We set this limitation because we have to comply with local country laws. We have already informed all our distributors this rule. Sorry for that and hope you can understand and forgive it. In this situation, we suggest you contact the seller to get a solution. |
| We are sorry to tell you that your vacuum cleaner is Non-Chinese version and can't work together with your other Mi devices with Chinese version under China Mainland server. This is because we have to comply with local country laws that device's data could not be saved in a server in China. Sorry for that and hope you can understand and forgive it. |
The model S6, S4 and S5 Max could save 3 maps. But they are not the maps for different floors. Only with multi-floor feature supported and enabled, can you create maps for different floors. (Take a quiz to know which Roborock for you) Recently, the latest firmware with multi-floor maps feature supported has been released for S5 Max and S6 in the Roborock app. If you customers need this feature, you can install the Roborock app to have a try. For other models, you can contact our technical support or check the firmware update on the APP to get further information.
Related FAQs:How many maps can Roborock S5 save? How to create multiple maps for multi-level house? How do I reset saved cleaning map? Can I make the robot cleaner clean specific rooms? |
| You could reset map like picture below to get a new map on app. |
You could merge or divide rooms by editting map. See pictures below.
Related FAQs:How many maps can robot cleaner save? How to create multiple maps for multi-level house? Can I make the robot cleaner clean specific rooms? |
Yes. Mi Home app supports the feature. You could use your phone to control the robot cleaner. It applies to all products. Roborock app has this feature, which applies to S4, S5 Max, S6, S6 Pure, S6 MaxV and S4 Max, and S7. |
We are sorry to tell you the device could not recognize the carpet and leave it away with mopping module installed. I'm afraid you need uninstall the mopping module before it cleans the carpet.
Related FAQs:Why does robot cleanner refuse to clean the shag carpet? Why does robot cleanner refuse to clean the dark carpet? Why isn't Carpet Boost activated on carpets? Can I add cleaner into the water tank when moppings? What's the meaning of carpet boost mode in robot cleaner's setting? |
No. We recommend adding water into it regularly.
Related FAQs:Will I receive an alert when the dustbin is full? Can I add cleaner into the water tank when moppings? What should I do when there is little water leaking from tank and mopping cloth is almost dry? |
We are sorry to tell you that our products do not alert when a dustbin is full, only when it has not been emptied for an extended period. We recommend emptying the dustbin regularly.
Related FAQs:Will I receive an alert when the water tank is empty? What does "MAX" on the transparent dust bin mean?
Related Tutorials Video:Roborock S6 Emptying and Cleaning the Dustbin Roborock S5 Emptying and Cleaning the Dustbin |
Related FAQ: |
Yes. Enable map saving mode and simply tap on the room you want cleaned in the app and the robot will clean that room. See picture below.
Related FAQs:How to create multiple maps for multi-level house? |
1-855-960-4321
