support-us@roborock.com
1-855-960-4321
Helpline hours: 24/7, US only
②5GHz:
QRcode: Scan the QR code below to download and install the app:
App Store:
https://apps.apple.com/us/app/roborock/id1462875428
Google Play:
https://play.google.com/store/apps/details?id=com.roborock.smart&hl=en&gl=US
The following applied to all roborock products.
We do not recommend adding non-roborock cleaner into the water tank as bubbles created by the cleaner may block the filter. If you use roborock cleaner, please dilute it (dilution ratio 1:300) before using.
Mihome app user
You can check below table for more information.
How long does it take to charge the Roborock H6?
Why is the battery not full even after charging for a long time?
The climbing ability of all the products, except S4 is 2cm (0.79inch), including S6 MaxV, S6 Pure, S6, S6 Max, S5, E4, E2/E3, C1, while the S4 is 1.5 cm (0.59inch).
When robot is creating the first map.
1. Map saved mode is enabled.You can go to "Vacuum settings" page or "Edit map" page.
2. Robot starts from dock.
3. Robot goes everywhere on map it detects to clean, not just somewhere. Pls make sure the doors are open for the rooms you want to be displayed on map.
4. Robot returns to dock(whose position is not moved) by itself and successfully.
MI ID A: Owner of device
MI ID B: Who wants to have device from owner.
But please notice the shared function is designed to just allow some basic features to be used by account shared. If MI ID B needs the whole features of device, we suggest he uses the owner's Mi account as one Mi account could be signed in on multiple phones.
Can multiple people control the robot by using different Mi accounts?
We are so sorry to tell you S5 could only save one map at present. It will recreate a new map and delete previous barrier or no-go-zone once you move it to another floor.
Related FAQs:How do I reset saved cleaning map? How do I create/delete no-go zones and invisible walls on app? |
Roborock Home is a skill that will allow users to bind their Mi ID to the Alexa. After account linked, users will be able to control the Roborock devices via Alexa.
Note: Make sure your robot is added and online on Mi Home app first.
Note: At present, Alexa smart speaker could only start and stop robot by skill Roborock Home or Mi Home.
You could set schedule cleaning on app. See picture below:
How do I set schedule cleaning for Roborock E series?
Why does S6 MaxV not support scheduled room cleaning anymore?
Will Roborock robot support scheduled room cleaning with multi-floor maps feature enabled?
Roborock S5 series has three products. The only difference among them is the deivces' color. Roborock S50 is white, S51 is rose gold and S55 is black.
For reset Roborock S5 :
Step 1. Hold the recharge button for 3-5 seconds.
Step 2. Use a pin to press the reset button next to wifi LED just once,and power button, recharge and spot cleaning button's light will be out. When you are doing this, please make sure recharge button is still under your finger's holding without moving.
Step 3. Keep holding recharge button for 5 seconds after you press reset button until power button blinks again and you hear the tone restore, and then you could remove the finger.
Notice:
Standard dock can operate between 100 V-240 V AC (Volts Alternating Current).
Auto-Empty Dock (or any dock with emptying function) works as follows:
US version: 100V-120V
EU version: 220V-240V
AU version: 220V-240V
JP version: 100V-127V
KR version: 220V-240V
TW version: 100V-127V
RU version: 220V-240V
UK version: 220V-240V
Check your regional voltage before use.
Yes. Onboard cliff sensors will detect any drops and prevent the robot from falling.
Related FAQ:What is the maximum height of a threshold that Roborock can pass over? |
Related FAQ:
Notes:
Note:
Related FAQ:
| We are sorry to tell you that your device is Chinese mainland version which could only be accessed on app in China mainland. We set this limitation because we have to comply with local country laws. We have already informed all our distributors this rule. Sorry for that and hope you can understand and forgive it. In this situation, we suggest you contact the seller to get a solution. |
| We are sorry to tell you that your vacuum cleaner is Non-Chinese version and can't work together with your other Mi devices with Chinese version under China Mainland server. This is because we have to comply with local country laws that device's data could not be saved in a server in China. Sorry for that and hope you can understand and forgive it. |
| You could reset map like picture below to get a new map on app. |
How to create multiple maps for multi-level house?
Can I make the robot cleaner clean specific rooms?
Yes. Mi Home app supports the feature. You could use your phone to control the robot cleaner. It applies to all products. Roborock app has this feature, which applies to S4, S5 Max, S6, S6 Pure, S6 MaxV and S4 Max, and S7. |
We are sorry to tell you the device could not recognize the carpet and leave it away with mopping module installed. I'm afraid you need uninstall the mopping module before it cleans the carpet.
Related FAQs:Why does robot cleanner refuse to clean the shag carpet? Why does robot cleanner refuse to clean the dark carpet? Why isn't Carpet Boost activated on carpets? Can I add cleaner into the water tank when moppings? What's the meaning of carpet boost mode in robot cleaner's setting? |
No. We recommend adding water into it regularly.
Related FAQs:Will I receive an alert when the dustbin is full? Can I add cleaner into the water tank when moppings? What should I do when there is little water leaking from tank and mopping cloth is almost dry? |
We are sorry to tell you that our products do not alert when a dustbin is full, only when it has not been emptied for an extended period. We recommend emptying the dustbin regularly.
Related FAQs:Will I receive an alert when the water tank is empty? What does "MAX" on the transparent dust bin mean?
Related Tutorials Video:Roborock S6 Emptying and Cleaning the Dustbin Roborock S5 Emptying and Cleaning the Dustbin |
Related FAQ: |
1-855-960-4321
