support-us@roborock.com
1-855-960-4321
Helpline hours: 24/7, US only
②5GHz:
The primary enhancements of the Qrevo Slim over the Qrevo Master include:
1. Navigation and Obstacle Recognition: Utilizes 3D ToF technology, an Optical Flow Sensor, and an RGB camera for improved navigation and obstacle recognition, which can detect distance more comprehensively and efficiently.
*the Qrevo Master used structured light, LDS, and an RGB camera for these functions.
2. More thin. The height of the Qrevo Slim is 8.2 cm which increases the cleaning area and allows it to enter low spaces.
*the height of Qrevo Master is 10.3 cm.
3. Increased Suction Power: Boosts maximum suction power to 11000 Pa, up from 10000 Pa on the Qrevo Master.
All other features remain consistent with the Qrevo Master, including compatibility with the same dock station. For example:
1. Both models include essential functions such as Auto-Empty, 60℃-Hot-Water Mop Washing, Automatic Water Refilling, and Automatic Drying.
2. They all come with 4 carpet modes, Quick Cleaning, Dirty Area Detection & Smart Re-mopping, FlexiArm™ Design Side Brush, FlexiArm™ Mopping System, and High-Speed Rotating Mop Cloths.
Furthermore, here's a link where you can compare the details of all models:
https://us.roborock.com/pages/robot-vacuum-cleaner-compare
Place the dock on a hard, flat floor (wood/ tile/concrete etc.), flat against a wall, and reserve a space of at least 0.9 m (2.9 ft) in height, 0.4 m (1.3 ft) in width, and 1.2 m (3.9 ft) in depth.
No, it doesn’t.
Black only.
The biggest advantage is its high integration. One module solves all problems and does not rely on mechanical rotation, which improves stability, reduces the height of the robot, and frees up space for other functions. At the same time, it can effectively reduce the height of the robot (from 10.3 cm to 8.2 cm), thereby improving the overall capabilities of the robot.
1-855-960-4321
