support-us@roborock.com
1-855-960-4321
Helpline hours: 24/7, US only
Under typical use, Qrevo S Pro operates at about 59 dB—roughly as quiet as a library—and only 45 dB during drying.
It offers up to 180 minutes of runtime (*Based on internal manufacturer testing under these conditions: quiet mode, hard floors, fully charged battery, and without the mopping module installed. Actual performance may vary depending on your home environment and the cleaning mode used.)
It comes with a 5,200 mAh built-in battery and takes about 4 hours to charge from 15% to full.
Qrevo S Pro adopts Reactive Tech obstacle avoidance technology. With structured light, ultrasonic, and infrared sensors, it accurately navigates around obstacles without bumping into furniture. The app also offers Less Collision mode with three adjustable sensitivity levels.
The multifunctional dock of Qrevo S Pro supports 75°C (167°F) hot-water mop washing, 45°C (113°F) hot-air drying, automatic emptying, and automatic water refilling.
Qrevo S Pro uses a new high-speed rotate mopping system. The mop modules rotate inward at 200 RPM, applying continuous pressure to the floor for deeper cleaning and a more thorough mopping performance.
Qrevo S Pro delivers highly effective cleaning with 18,500 Pa suction power and can cover up to 290 square meters on a single charge. With its auto-lifting mop module, it can easily clean carpets in vacuum-only mode.
Building on Qrevo S5V/QV 35A/QV 35S, Qrevo S Pro offers several feature upgrades:
In addition, Qrevo S Pro introduces new app features, including “Remove” under “Edit Room,” which allows users to remove rooms from the map.
For a detailed guide to the Roborock app and its main features, please see our App User Guide.
https://gl-files.roborock.com/app-manuals/54fb3c0a2c94a536a3ecc501bb7430977b4e250d4b376d88.pdf
The guide provides step-by-step instructions for using the app. Please note that some features are model-specific, so certain options may not appear on your device. The app interface may also vary slightly by model or app version. Screenshots are for reference, while the basic steps and functions remain generally applicable.
If you need further assistance, just let us know.
1-855-960-4321
