support-us@roborock.com
1-855-960-4321
Helpline hours: 24/7, US only
②5GHz:
①. The maximum suction power of Qrevo S is 7000Pa, compared to Qrevo's maximum of 5500Pa.
②. The dustbin capacity of Qrevo S is 330ml, slightly less than Qrevo's 350ml.
③. Qrevo S features Roborock Smart Plan, which automatically adjusts cleaning modes based on home environment and past cleaning habits, unlike the Qrevo.
④. Qrevo S offers additional features such as "Add Area" for targeted re-cleaning and "Skip Area" to by pass specific area for efficiency, both of which are not available on the Qrevo.
⑤. Qrevo S allows the robot to traverse carpets without engaging in cleaning upon detection, a capability not present in the Qrevo.
Keep a space of clearance about 0.9 m (2.9 ft) in height, 0.4 m (1.3 ft) in length and 1.2 m (3.9 ft) in width. Place the dock on a hard and flat floor (wood/tile/concrete etc.), flat against a wall.
Yes, Qrevo S has a built-in drying module which supplies warm air to dry both mops and cleaning tray.Meanwhile, the mop modules will rotate periodically to allow even drying.
The cleaning tray is detachable for easier maintenance. During the mop washing process, the dirt on the mops will be removed by the washing scrapers on the cleaning tray and users need to remove and clean the tray regularly.
Yes, Qrevo S is equipped with an electric water tank. You can set up different water flow in the app according to your floor conditions.
Qrevo S has the new high-speed rotating mopping system. The mop modules rotate inwards at 200 revolutions per minute, providing constant pressure on the floor for deeper cleaning and mopping.
It is recommended to only use Roborock cleaning solution in the water tank. Other cleaning solutions may have different formulations that could potentially damage the water tank. Additionally, bubbles produced by chemical substances in cleaners may cause the mopping feature to malfunction. If you use the Roborock cleaner, please dilute it (dilution ratio 1:300) before use.
You can find more information at the following link:
1-855-960-4321
