support-us@roborock.com
1-855-960-4321
Helpline hours: 24/7, US only
②5GHz:
Similarities:
1. All models include essential functions such as Auto Dust Emptying, Mop Self-Washing, Auto Tank Refilling, Detachable Dock Base and Warm Air Drying.
2. They all come with 4 carpet modes, Temporary cleaning, FlexiArm Design™ mopping System, and high-speed rotating mop cloths.
3. Each model features an 80ml built-in water tank, a 4L clean water tank, and a 3.5L dirty water tank.
4. They all come with 7000 Pa maximum suction power and a single rubber main brush.
5. All models support 10mm Mop lifting to avoid wetting the floor in vacuum only mode (Mop pad will lift 7mm).
Differences:
1. Qrevo MaxV and Qrevo Pro feature Hot-Water Mop Washing, Dirty area detection & smart re-mopping, while Qrevo Plus does not.
2. Qrevo MaxV has an automatic brush and mop lifting function, while Qrevo Pro and Qrevo Plus only have an automatic mop lifting function.
3. Qrevo MaxV provides the features of Intelligent Voice Assistant and remote viewing, which Qrevo Pro and Qrevo Plus lack.
Here's a link where you can compare all models:
https://us.roborock.com/pages/robot-vacuum-cleaner-compare
There are four cleaning modes available: Smart, Light, Balanced, and Deep.
- Smart mode automatically adjusts the water volume and duration of mop washing based on the level of dirt.
- Light mode is suitable for clean environments, offering reduced cleaning time and water consumption.
- Balanced mode is ideal for medium-sized homes, providing a balance between cleaning speed and performance.
- Deep mode is suited for occasional deep cleaning, featuring higher water consumption and longer cleaning time.
Its side brush, main brush, main brush cover are compatible with that of QRevo. Its dustbin, filter, mop cloth is not compatible with any of QRevo.
No, Qrevo Pro supports obstacle avoidance, while doesn’t support obstacle photo view.
1). Type of water tank:
The model is equipped with an electronic water tank, which offers several water flow levels so you can fine-tune cleaning in app to match your floor types and preferences.
Note: the water tank on the robot is integrated.
2). Way of mopping:
a. It has 2 mop axles that can spin inwards to provide deeper cleaning performance.
b. It's equipped with the FlexiArm Design mop, which can stretch out to cover edges, greatly improving edge cleaning ability.
Qrevo Pro tank volume is 80ml (Robot water tank). Clean water tank in dock is 4L.
Qrevo Pro vacuum duration with full battery (balanced mode): 150min.
Qrevo Pro dustbin volume is 330ml.
The default wash frequency is set to 15 minutes, which can be adjusted on the wash settings page of the app. If necessary, you can also initiate mop washing manually by pressing and holding the Dock button while the robot is on the dock.
Yes, the robot cleaner can operate without Wi-Fi and perform full-home cleanups, spot cleanups, and return to the dock with the push of a button. Additionally, it can perform basic voice commands. Connecting to Wi-Fi unlocks advanced features such as scheduled cleaning, selection of suction power strength, and more.
It is recommended to only use Roborock cleaning solution in the water tank. Other cleaning solutions may have different formulations that could potentially damage the water tank. Additionally, bubbles produced by chemical substances in cleaners may cause the mopping feature to malfunction. If you use the Roborock cleaner, please dilute it (dilution ratio 1:300) before use.
You can find more information at the following link:
1. With the Add Area feature, you can select an additional area for cleaning in the middle of a cleaning session. The robot will prioritize cleaning the newly selected area first.
2. With the Skip Area feature, you can instruct the robot to skip the current area during the cleaning process and move on to the next area.
Vacuum carpet first: The robot will vacuum carpets identified on the map when a cleaning cycle is initiated. It will then return to wash the mop pads and clean the remaining areas.
Deep carpet cleaning: The robot will vacuum carpets identified on the map twice using a cross-hatch pattern for thorough cleaning.
What distinguishes the "Cross" mode from the "Rise" mode in obstacle avoidance? There are four obstacle avoidance modes:
1. Rise: When a carpet is detected, the mop lifts and water flow stops for carpet vacuuming.
2. Avoid: The robot completely avoids carpets.
3. Ignore: Ideal for environments without carpets or where mats can be mopped.
4. Cross: Crossing mode is suitable for door mats or carpets. It crosses them without cleaning.
The dustbin filter inside the robot is an E11 filter (Efficient Particulate Arrestance filter 11 or EPA 11), rather than HEPA. It effectively removes 95% of particles with a size equal to or greater than 0.3 μm.
The robot features a rubber brush with detachable ends on both sides.
To prevent corrosion or damage, only use Roborock branded floor cleaner in the water tank.
The link below is for reference:
For a detailed guide to the Roborock app and its main features, please see our App User Guide.
https://gl-files.roborock.com/app-manuals/54fb3c0a2c94a536a3ecc501bb7430977b4e250d4b376d88.pdf
The guide provides step-by-step instructions for using the app. Please note that some features are model-specific, so certain options may not appear on your device. The app interface may also vary slightly by model or app version. Screenshots are for reference, while the basic steps and functions remain generally applicable.
If you need further assistance, just let us know.
1-855-960-4321
