support-us@roborock.com
1-855-960-4321
Helpline hours: 24/7, US only
②5GHz:
Similarities:
1. All models include essential functions such as Auto Dust Emptying, Mop Self-Washing, Auto Tank Refilling, Detachable Dock Base and Warm Air Drying.
2. They all come with 4 carpet modes, Temporary cleaning, FlexiArm Design™ mopping System, and high-speed rotating mop cloths.
3. Each model features an 80ml built-in water tank, a 4L clean water tank, and a 3.5L dirty water tank.
4. They all come with 7000 Pa maximum suction power and a single rubber main brush.
5. All models support 10mm Mop lifting to avoid wetting the floor in vacuum only mode (Mop pad will lift 7mm).
Differences:
1. Qrevo MaxV and Qrevo Pro feature Hot-Water Mop Washing, Dirty area detection & smart re-mopping, while Qrevo Plus does not.
2. Qrevo MaxV has an automatic brush and mop lifting function, while Qrevo Pro and Qrevo Plus only have an automatic mop lifting function.
3. Qrevo MaxV provides the features of Intelligent Voice Assistant and remote viewing, which Qrevo Pro and Qrevo Plus lack.
Here's a link where you can compare all models:
https://us.roborock.com/pages/robot-vacuum-cleaner-compare
The cleaning tank is detachable for easier maintenance. During the mop washing process, the dirt on the mops will be removed by the washing scrapers on the cleaning tank and users need to remove and clean the tank regularly.
Keep a space of clearance about 0.9 m (2.9 ft) in height, 0.4 m (1.3 ft) in length and 1.2 m (3.9 ft) in width. Place the dock on a hard and flat floor (wood/tile/concrete etc.), flat against a wall.
1). Type of water tank:
The model is equipped with an electronic water tank, which offers several water flow levels so you can fine-tune cleaning in app to match your floor types and preferences.
Note: the water tank on the robot is integrated.
2). Way of mopping:
a. It has 2 mop axles that can spin inwards to provide deeper cleaning performance.
b. It's equipped with the FlexiArm Design mop, which can stretch out to cover edges, greatly improving edge cleaning ability.
It is recommended to only use Roborock cleaning solution in the water tank. Other cleaning solutions may have different formulations that could potentially damage the water tank. Additionally, bubbles produced by chemical substances in cleaners may cause the mopping feature to malfunction. If you use the Roborock cleaner, please dilute it (dilution ratio 1:300) before use.
You can find more information at the following link:
1-855-960-4321
