support-us@roborock.com
1-855-960-4321
Helpline hours: 24/7, US only
②5GHz:
It supports obstacle recognition and viewing obstacle photos.
Obstacle recognition means the robot will be able to recognize and avoid objects with the camera. The real-time obstacle icon also will be shown in map.
Viewing obstacle photos means you can view photos of identified objects on the map page. One image will be stored onboard for every object recognized. Some object images may not be stored.
Similarities:
①. All models include essential functions such as Auto-Empty, Hot-Water Mop Washing, Water Refilling, and Auto-Drying.
②. They all come with 4 carpet modes, Temporary cleaning, Dirty area detection & smart re-mopping, FlexiArm Design™ mopping System, and high-speed rotating mop cloths.
③. Each model features an 80ml built-in water tank, a 4L clean water tank, and a 3.5L dirty water tank.
Differences:
①. Only Qrevo Master is equipped with the FlexiArm Design™ Side Brush.
②. Qrevo Master comes with a DuoRoller Riser™ Brush, which improves cleaning efficiency over the single main brush of Qrevo Pro and Qrevo MaxV.
③. Qrevo Master's cleaning tray features self-cleaning, while Qrevo Pro and Qrevo MaxV do not.
④. Qrevo MaxV and Qrevo Pro have a maximum suction power of 7,000 Pa, while Qrevo Master has 10,000 Pa.
⑤. Both Qrevo Master and Qrevo MaxV have an automatic brush and mop lifting function, while Qrevo Pro only has an automatic mop lifting function.
⑥. Qrevo MaxV and Qrevo Master have an Intelligent Voice Assistant and remote viewing feature, which Qrevo Pro lacks.
①. The maximum suction power of Qrevo Master is 10000Pa, significantly higher than Qrevo's maximum of 5500Pa.
②. Qrevo Master comes with a DuoRoller Riser™Brush, which improves cleaning efficiency over Qrevo's single main brush. Moreover, both the main brushes and mop modules of Qrevo Master are designed to be liftable, whereas Qrevo only features a mop lifting.
③. Qrevo Master features an 80ml built-in water tank, a 4L clean water tank, and a 3.5L dirty water tank. In comparison, Qrevo also boasts the same 80ml built-in capacity, along with a larger 5L clean water tank and a 4.2L dirty water tank.
④. Qrevo Master includes Roborock Smart Plan, which automatically adjusts cleaning modes based on the home environment and past cleaning habits, unlike Qrevo.
⑤. Qrevo Master offers additional features such as "Add Area" for targeted re-cleaning and "Skip Area" to bypass specific areas for efficiency, neither of which are available on Qrevo.
⑥. There is a heating module inside Qrevo Master's dock to heat water in the clean tray to 60℃. With 60℃ hot water, most greasy dirt can be dissolved, such as beef tallow, mutton tallow, starch, etc., while Qrevo only uses room temperature water to wash the mops.
⑦. Qrevo Master features an Intelligent Voice Assistant and remote viewing capability, which Qrevo lacks.
⑧. Qrevo Master supports dirty area detection and smart re-mopping features, unlike Qrevo.
①. It features a rotating mopping system with two inward-rotating mop axles spinning at high speed for deep cleaning. Additionally, it is equipped with a FlexiArm Design™ Edge Mopping System and FlexiArm Design™ Side Brush System, which aids in achieving spotless corners and edges effortlessly as the robot extends its mop and side brush, ensuring precise edge coverage.
②. The robot is equipped with a DuoRoller Riser™ Brush and its maximum suction power is 10000 Pa. Both the main brush and mop module are designed to be liftable.
③. It supports a multifunctional dock that offers rapid charging, hot-water mop washing, automatic filling of the onboard water tank, quick auto-emptying of the onboard dustbin, and warm air drying of wet mops and the cleaning tray.
④. The cleaning tray, where the mops are washed, features a self-cleaning function.
⑤. Equipped with a built-in Intelligent Voice Assistant, you can easily initiate cleanups by saying “Hello Rocky” even without a WiFi connection.
⑥. Utilizing structured light and an RGB camera, the Qrevo Master is capable of achieving a Video Call feature. Real-time video calls and two-way voice interaction enable you to 'talk' with your adorable pets in a unique manner.
⑦. It offers four Carpet Avoidance Modes, allowing you to customize cleaning preferences by selecting which carpets and rugs need to be cleaned, skipped or ignored.
⑧. It supports dirty area detection and smart re-mopping features, which means it will automatically re-mop areas with stubborn dirt and stains, the floors will be mopped again to ensure they are thoroughly cleaned.
Yes, Roborock Qrevo Master has a built-in drying module which supplies warm air to dry both mops and cleaning tray. Meanwhile, the mop modules will rotate periodically to allow even drying.
The cleaning tray is detachable for easier maintenance. During the mop washing process, the dirt on the mops will be removed by the washing scrapers on the cleaning tray and users need to remove and clean the tray regularly.
Yes, Roborock Qrevo Master is equipped with an electric water tank. You can set up different water flow in the app according to your floor conditions.
Roborock Qrevo Master has the new high-speed rotating mopping system. The mop modules rotate inwards at 200 revolutions per minute, providing constant pressure on the floor for deeper cleaning and mopping.
It is recommended to only use Roborock cleaning solution in the water tank. Other cleaning solutions may have different formulations that could potentially damage the water tank. Additionally, bubbles produced by chemical substances in cleaners may cause the mopping feature to malfunction. If you use the Roborock cleaner, please dilute it (dilution ratio 1:300) before use.
You can find more information at the following link:
1-855-960-4321
