support-us@roborock.com
1-855-960-4321
Helpline hours: 24/7, US only
Yes. Qrevo Edge 2 Flow has a camera on the front and it features obstacle avoidance and video calling. Powered by structured light and an RGB camera, it intelliGently detects and avoids over 280 types of clutter with precision day and night.
Its core technology is a "roller mop + real-time fresh water mopping" system.
Each of these three mainstream systems has distinct strengths. The appropriate choice depends on your primary cleaning needs.
No. This robot is mainly designed for everyday floor cleaning. Its on-board dirty water tank has a limited capacity, and the robot is not designed to suction up liquid. Therefore, it is not suitable for cleaning up standing water in a bathroom or liquid spills exceeding 50 mL. In such cases, a cloth or mop should be used first.
1. 16 pressurized water outlets
Compared with an 8-outlet design, 16-outlet design with pressurized spraying distributes water more evenly, keeping the roller moist and helping reduce water marks.
2. 240 RPM high-speed scrubbing with 15 N downward pressure and a 270 mm (10.63 in) extra-wide roller
More rotations in the same amount of time increase friction with the floor, helping remove dirt more effectively. It breaks down stains with high speed and high efficiency, scrubbing and mopping simultaneously for cleaner floors.
3. The floating scraper and all-new upgraded microfiber roller 2.0 help remove excess water while mopping, reducing water marks after cleaning.
When carpet is detected, the roller mop automatically lifts by up to 15 mm (0.59 in), while the roller mop cover will be slid out at the same time to create a physical barrier. This ensures vacuum-only cleaning and helps protect your carpet.
The new reversible right side brush features a special design that delivers different benefits depending on its rotation direction:
Qrevo Edge 2 Flow includes all the features of Qrevo Curv 2 Flow, with a square-shaped dock, higher suction power, liftable LDS, an upgraded SpiraFlow mopping system, an upgraded reversible right side brush, an upgraded robot dirty water tank design, and a higher drying temperature.
For a detailed guide to the Roborock app and its main features, please see our App User Guide.
https://gl-files.roborock.com/app-manuals/54fb3c0a2c94a536a3ecc501bb7430977b4e250d4b376d88.pdf
The guide provides step-by-step instructions for using the app. Please note that some features are model-specific, so certain options may not appear on your device. The app interface may also vary slightly by model or app version. Screenshots are for reference, while the basic steps and functions remain generally applicable.
If you need further assistance, just let us know.
1-855-960-4321
