support-us@roborock.com
1-855-960-4321
Helpline hours: 24/7, US only
The Qrevo Edge S5A and Qrevo Curv S5X share the same advanced robot vacuum technology and offer identical functionality in terms of cleaning performance. The major differences between the two models lie in the design of the docking station. These design variations cater to different user preferences and specific needs, but the core cleaning capabilities remain the same.
The DuoDivde brush is certified by SGS with 0% hair entanglement rate and 100% hair removal rate. It solves the problem of decreased cleaning efficiency caused by hair entanglement on the main brush and reduces the risk of main brush damage due to hair entanglement, making the robot vacuum cleaner more durable.
The Qrevu Curv S5X and Qrevo Curv share many features but also have key differences:
Similarities:
Differences:
Qrevo Curv will automatically lift the omnidirectional wheel or main wheel to handle standard thresholds up to 3cm, and complex double-layer thresholds up to 4cm, while Qrevu Curv S5X can only cross the thresholds up to 2cm.
The Qrevu Curv S5X offers a more compact design and slightly reduced features compared to the Qrevo Curv, but it still provides powerful suction and effective cleaning performance.
The Qrevu Curv S5X offers a powerful cleaning experience with the following features:
1. Up to 18,500 Pa HyperForce Suction Power for strong cleaning performance.
2. Comprehensive anti-tangle system: Equipped with the DuoDivide brush, FlexiArm Design Arc Side Brush to prevent hair entanglement.
3. FlexiArm Design Side Brush & Mop for better edge cleaning.
4. LDS + Structured Light navigation: Efficient navigation and obstacle avoidance.
5. Height of 9.79 cm: Ideal for cleaning under low furniture.
6. Multifunctional dock with 75°C hot-water mop washing, auto-refilling of the onboard water tank, dustbin auto-emptying, and warm air drying for the mop cloths.
②5GHz:
1. The maximum suction power of Qrevo Curv is 18500Pa, significantly higher than Qrevo Master's maximum of 10000Pa.
2. Qrevo Curv comes with a DuoDivide Brush, FlexiArm Arm Side Brush and liftable omnidirectional wheel to achieve 0% hair entanglement, whereas Qrevo Master lacks.
3. Qrevo Curv is equipped with an advanced smart liftable chassis system, the two main wheels and omnidirectional wheel's versatile combinations enable easy obstacle overcome in complex environments like over door threshold, sunken floors, medium-pile carpets, and around furniture, boosting cleaning efficiency, whereas Qrevo Master lacks.
4. Qrevo Curv allows users to remove specific areas directly from the app, a feature not available on Qrevo Master.
5. There is a heating module inside Qrevo Curv's dock to heat water in the clean tray to 75℃. With 75℃ hot water, most greasy dirt can be dissolved, while Qrevo Master only uses up to 60℃ hot water to wash the mops.
Does Qrevo Curv support obstacle avoidance and video call feature?
It offers up to 75℃ high-temperature mop washing, automatic refilling of the onboard water tank, auto-emptying of the onboard dustbin, and warm air drying of mop cloths.
The DuoDivde brush is certified by SGS with 0% hair entanglement rate. It solves the problem of decreased cleaning efficiency caused by hair entanglement on the main brush and reduces the risk of main brush damage due to hair entanglement, making the robot vacuum cleaner more durable.
1. Up to 18500 Pa HyperForce Suction Power
2. Comprehensive anti-tangle system: Qrevo Curv is equipped with the revolutionary DuoDivide brush, FlexiArm Design Arc Side Brush and liftable omnidirectional wheel to achieve 0% hair entanglement.
3. FlexiArm Design Side Brush & Mop provide better edge cleaning.
4. Smart liftable chassis system: The two main wheels and omnidirectional wheel's versatile combinations enable easy obstacle overcome in complex environments like over door threshold, sunken floors, medium-pile carpets, and around furniture, boosting cleaning efficiency.
5. It comes with a multifunctional dock that offers 75℃ hot-water mop washing, automatic refilling of the onboard water tank, auto-emptying of the onboard dustbin, and warm air drying of mop cloths.
1-855-960-4321
