support-us@roborock.com
1-855-960-4321
Helpline hours: 24/7, US only
②5GHz:
Similarities:
Differences: The following features are unique to Flexi Pro.
When lowering the handle during operation, the vacuum cleaner can be positioned flat to clean low-lying areas. Please be aware that when the vacuum cleaner is in this flat position, the usable volume of the dirty tank is reduced.
Yes, it can detect if the dirty tank if full. If the water level reaches Max line during upright operation, the vacuum cleaner would give the voice message that the dirty tank is full, please empty it.
When lowering the handle during operation, the vacuum cleaner can be positioned flat to clean low-lying areas. When the vacuum cleaner is laid flat for cleaning, it will automatically adjust its operating mode.
The Flexi Pro is equipped with a dirt sensor that detects the level of dirt and then adjusts the cleaning power. If automatic mode is selected, the unit will increase the suction power and water output when it detects a dirty area, and reduce it if that area is already cleaned.
Complemented by the flow of 55°C (131°F) heated air, it will take 30 min to dry roller completely.
Flexi Pro is equipped with a 730 ml clean tank and a 450 ml dirty tank.
1-855-960-4321
