support-us@roborock.com
1-855-960-4321
Helpline hours: 24/7, US only
Compared with F25 RT / F25 GT, F25 RT Gen 2 / F25 GT Gen 2 introduces several key upgrades or enhancements:
1. Suction power: 20,000 Pa – Delivers strong suction for thorough cleaning on various surfaces.
2. Height when flat: 4.92 in / 12.5 cm – The vacuum can be laid flat to clean under furniture and appliances, ensuring deeper cleaning in hard-to-reach space.
3. Self-cleaning and drying temperature: 90°C.
4. Dual scrapers: Constant-pressure floating scraper + Anti-tangle comb scraper – The dual scrapers are designed to pick up hair and prevent it from tangling in the roller.
5. Roller system: Single roller + Edge cleaning (1 mm from each side).
6. Water tank volume: The clean tank holds 870 mL and the dirty tank 720 mL.
With up to 20,000 Pa of powerful suction, F25 RT Gen 2 / F25 GT Gen 2 delivers exceptional cleaning performance. Combined with FlatReach® 2.0 and a 70° swivel design, it effortlessly reaches under furniture and glides smoothly around obstacles. In addition, it is engineered for a quieter and more comfortable cleaning experience, with noise levels of 70 dB in ECO mode, 74 dB in MAX mode, and 74 dB during self-cleaning. In Quiet Drying mode, the noise level is reduced to just 48 dB.
F25 RT Gen 2 / F25 GT Gen 2 is equipped with a 2,500 mAh battery. In ECO mode, it provides up to 38-minute of runtime, covering approx. 284 m² (3,057 ft²). In MAX mode, it provides up to 22-minute of runtime, covering approx. 167 m² (1,798 ft²).
Yes. It is elaborately designed for everyday convenience:
F25 RT Gen 2 / F25 GT Gen 2 is equipped with an 870 mL clean tank and a 720 mL dirty tank. With a full clean tank: In MAX mode, the clean tank water supply lasts for over 22 min. In ECO mode, the clean tank water supply lasts for over 38 min. The large-capacity tanks minimize the need for frequent refilling and emptying, allowing you to clean larger areas with less interruption.
The charging dock of F25 RT Gen 2 / F25 GT Gen 2 features powerful self-cleaning and drying functions that are both convenient and energy-efficient:
1-855-960-4321
