support-us@roborock.com
1-855-960-4321
Helpline hours: 24/7, US only
The cliff sensors used on robot cleaner make the device may not be able to clean shag carpets because the long hairs may trigger the cliff sensors in the same way as a drop. At present, it is not possible to disable cliff sensors as they are essential in most homes.
Why does robot cleanner refuse to clean the dark carpet?
The cliff sensors used on Roborock robots may mean that the robot may not be able to clean dark carpet because dark carpets trigger the cliff sensors in the same way as a drop. At present, it is not possible to disable cliff sensors as they are essential in most homes. Hope you can understand and forgive this drawback.
Why does robot cleanner refuse to clean the shag carpet?
Try each of the following steps until the noise stops. After each step, run the robot briefly to see if the noise continues. If not re-install the part and move on to the next step until the noise stops. If the noise stops, clean the part thoroughly then reinstall it and try again.
- Remove the main brush and brush cover
- Unscrew and remove the side brush
- Uninstall the front wheel (keeping the front of the robot supported)
If the noise ceases when the front wheel is removed, after cleaning, pour no more than two drops of olive oil down the wheel shaft and rotate it to spread the oil before reinstallation.
If none of the above have stopped the noise, turn the driving wheels manually. If they are, the source of the noise, contact your Roborock dealer for further support.
The robot might experience issues returning to its dock if it was started in a different location, if it is hitting an obstacle, or if it was moved manually. If this is occurring, try one of the below solutions:
Move the dock to a new location and see if the robot can locate it. The dock should be placed against a wall, have at least 0.5m of clearance either side and 1.5m in front. Then, clean the front signal transmission area of the dock and the robot’s front sensor, both of which are used for the robot to locate the dock.
Check the blocked strainer, and repalce the filter to see if the problem is solved.
If you continue to experience this error, contact Roborock Customer Support.
Roborock Internal Error: Restore the robot cleaner to factory setting. If you continue to experience this error, contact Roborock Customer Support.
Roborock Error 18: Clap the side of the robot several times to try and clear debris from the fan.
Roborock Error 10: Clean the filter, dry it thoroughly and place it back in the robot then try again.
Roborock Error 9: Look for the magnet on the side of the filter.
If you do not find a magnet, replace the filter and try again.
Roborock Error 5: Make sure that there is nothing tangling up the main brush, including inside the two brush installation slots and at either end of the brush, then run the robot with Carpet mode enabled and see if the problem has been resolved. If you continue to experience this error, contact Roborock Customer Support.
Roborock Error 4: Wipe the cliff sensors and make sure the robot cleaner is not on the dark or shag carpet. If you continue to experience this error, contact Roborock Customer Support.
1-855-960-4321
